fd rims on a 1g
I run FD wheels and AGX rear shocks. I have 10mm spacers in the rear and had to buzz down the weld on the rear control arms a tiny bit to clear. My tires are 225/50/16. I think the front fit ok, but with out spacers, i couldn't install the FD center caps on the front wheels.
:thumb: im planning on running same tire size just a drag radial instead:hellyeah:
i had to grind the rear control arm and i have 5mm spacers on all 4
(and i had to cut a tab off the oem front shocks from the abs but i removed the abs so it was easy
I have found a set of fd rims and planning on buying them this week. I have changed my tire setup idea and not sure how they will fit, tires im planning on gettin are nitto 555r"s 245/50/16.. Ive been doing research on tire size"s and noticied that the is no smaller Wight then a 245 for a 16in rim :confused:.. Btw im changing the agx out for a coilover since im pretty sure a tire such as a 245 will rub on a strut
