failed smog
sharky559
191
Mar 6, 2010
Sanger, California
Well I took the 2g to get smog changed. Pass the visual but failed emissions. And they called my car a gross polluter. Don't know what's going on. I have no check engine light. Need help. Any ideas on what could be the problem. ...
Didn't they give you a report of what failed? It makes a big difference as to what it is polluting exactly. Its hard to give recommendations without more information.
Usually the smog technician will tell you what could cause the problem if you ask them, also post the paperwork so that people can see the report. Last time this happened to me on my truck he said to change the spark plugs and pcv valve, I did and it past the next day. Good luck :thumb:
%co2 %o2 HC(PPM) CO% NO(PPM)
Test RPM MEAS MEAS MAX GP MEAS MAX GP MEAS MAX GP MEAS
15mph 1645 11.8 2.8 87 247 265 0.51 2.01 1.88 701 1930 527 Fail
25mph 1818 10.6 3.6 52 224 266 0.49 1.99 3.18 730 1730 464 Gross polluter
that's what the test result say. let me know what happend
