failed smog please help
azkikr10
330
3
Jan 12, 2003
Union City, California
well i failed smog today as stated above. i qualify as a "goss poluter" my mods are afc 2 , 660 injects. fuel pump , and evo 16g. i know im untuned as hell. im swapping back to stock injectors tomarrow but is there anything else i should do? should i lean out my afc another 10%? you probably want to know where i failed.
hc (ppm)
max mine
idle 120 486
2500rpm 140 238
co%
idle 1.00 8.64
2500rpm 1.00 6.7
i think i may win the prize for biggest 1g polluter but thats not good. LOL any ideas? also i want to know if anyone has got worse than that.
new plugs, new wires, put back stock exhaust, and stock injectors, run some fuel injector cleaner through the system, with the highest octane gas you can get, then re-fuel with the highest octane and go test again and you should be fine.
