turbotoad
- 57
- 2
- Jun 26, 2004
Clarkston,
Michigan
Just bought some factory fog lights for my 96 Talon. The problems is that the car was not originally equipted with them. So I'm not sure what all needs to be done to get the Fog lights working.
I read somewhere that all non-fog vehicles were "wired" from the factory and all that was need was the OEM switch, OEM relay, and fuse. But I looked around under/behind the front end and found NO wiring provisions from the headlight wire harness (i.e. no wire leads or connectors for fog lights). And I'm not sure there are even any "fog light" wires present at the under-hood fuse block or behind the switch cover plate.
Has anyone made this swap before? What are the parts and steps I need to take in order to make the fogs work? (non-stock switch and wiring would be ok)
I looked the car over for about an hour or so last night and could find no fog light wires/harness anywhere on the main electrical harness. On top of that, I examined the underhood fuse box and found that there are absolutely no wires/end-connectors attached to the fog light switch relay port. And only a single end-connector present in the inboard side of the fog light fuse port. So it appears my car was NOT wired for fog lights from the factory!
