Putting Fogs where there are none on a 2g RS
ForsakenLash
156
Mar 15, 2013
Jacksonville, Florida
So I tried looking around through search and didnt get a concrete answer on my questions about putting fog lights on my 2g RS... so here it goes.
If I wanted to put some in, what all would I need off of the junker I pull them from? Are the brackets already there? wiring harness?
If the harness isnt already there where would you suggest I wire them into? Would it be legal to just wire them into the low beams?
Also this is the dumb question so I saved it for last, the plastic pieces on the bumper where the Fogs would normally be, do those pieces just come out or will it require some modding?
Thanks for the help.
You would need the mounting brackets along with the lights, and the wiring. I wired mine into a switch i got from autozone and they worked like OEM. I HIGHLY suggest taking the stock connectors for the fogs also. And you could cut your bezzels ( the plastic pieces), or find the ones that came on stock eclipses with fogs. I just cut the vents.
PS: The bezzels come out by undoing a screw.
