1G F4A22 stuck in limp mode
Ejsmith50
Apr 21, 2015
Newburgh, Indiana
Hello, I have a 1991 Laser LS stuck in limp mode. Have codes 45, 47 & 85. No ECU codes. Have a bunch of hours researching this. TCU is fairly new. Trans works fine on home made simulator switch. Has correct volts on each pin on inhibitor plug and ohm'ed inhibitor switch, also fairly new.
Haven’t purchased transmission service manual, yet. May be next move
Hello, I have a 1991 Laser LS stuck in limp mode. Have codes 45,47 & 85. No ecu codes. Have a bunch of hours researching this. Tcu is fairly new. Trans works fine on home made simulator switch. Has correct volts on each pin on inhibitor plug and ohmed inhibitor switch, also fairly new. Haven’t purchased transmission service manual, yet. May be next move
Scroll down for codes http://w4a33.com/doku.php?id=tcu
Thanks for the info & link. Had the four wire plugs switched, because the one for solenoids was too short to clip on holding bracket, so I didn’t think it went there. After checking voltage on both 4 pin connectors, I found that the pulse generator pins had 2 volts. Then it made since. Now kills engine when put in gear. Glad to have a different problem to chase. thanks
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
