2G Extreme clunking/slipping noise
Jonathan Weir
Feb 8, 2017
St Constant, QC, Canada
Hey guys need some help.
Car makes violent clunking noise and sometimes it wont even move.
Both front axles are new tried 2 transfer cases driveshaft feels good no extreme wiggle.
There are no leaks anywhere all suspension parts feel tight and good.
Check this video out I took, it gets bad near the end
I believe its the center diff. Off with the tranny I guess
Yeah that is probably an accurate assumption. Especially if you can pinpoint the noise to the transmission. If you know the axles and Transfercase are good then it's going to be something internally in the transmission more than likely. The center diff / intermediate shaft is a good place to start.
