Clunking Noise While Starting
19GS-t97
82
Feb 23, 2005
Barnegat, New Jersey
Ok so i just got back from school and the dsm has been sitting for about 2 months. When i went to start it for the first time, there was a metal clunking sound going on around where my feet are. It only happens when i am starting the car. Also when i make left turns sometimes it sounds like a clicking axle, but i just replaced the left axle so im thinking this is part of the clunking problem. The car drives like any regular car once i am actually driving. It is only when im starting the car. Any ideas?
Thanks:dsm:
I get similar issues on cold starts and I've isolated it to the motor moving around a bunch on the stock mounts. I'd have a friend start the car and see if you can isolate the noise but that where my startup knock seems to come from. I also have a motor that moves a great deal at idle due to my cam settings and that doesn't seem to help motor mount wear. I'd take a good look at them and make sure that everything's tight and also check to see if they're torn.
Let us know what you find. Knock on!
Andy
Thanks for the reply...i'll have the car on the lift on sunday or monday so hopefully i'll find something out.:dsm:
the starter bolt was loose...tightened it up and it fixed the problem
