exhaust smoke
playboy1884
81
Dec 22, 2002
ozark, Arkansas
hwhen i start my car i can rev n let of n fan and it will puff a 1 sec puff of smoke then stop , i raced a corvette and we were doin about 130 oin the istate for around 5 mins thats 5500 rpm min and then it was leakin a lil oil the intercooler had oil in it also.... so does the turbo have blowby could that cause it ??? or piston rings how do i check ?
Its cool just hard to read. Compression test:
1) you need a compression tester ( Pep Boys, Napa, any autoparts store) 15-40 bucks
2) drive the car around, and sorta beat on it. Get on it alot, and warm it up nice. You will get a better reading than just idle to normal temp
3) Remove all Spark Plugs
4) Go into the fuse box under the hood attatched to the battery, and take out the MPI Fuse
5) thread the compression tester into each cylinder
6) have someone crank over the car AT WIDE OPEN THROTTLE several revolutions, or until the guage stops climbing. Were is stops is ur compression # in that cylinder
7) Repeat in that order for the next 3 cylinders
Stock 1G Turbo Compression is 160
Service limit is 120 ( i think)
Goood Luck
ok i will do the comp test and my car leaks oil btw .... but yea it needs a new head gasket i am told. .. umm what if it isnt that tho.... i'm gonna go check teh coolant right now. then go to napa n fetch me a compression checker.
yeah same here, all I did was warm up the car. I didn't have time since I did it right before I got ready for work. The only thing I disconnected was the coil, and I didn't crank it with it at WOT, I just cranked it. I still got 165 across the board.
