exhaust manifold leak
4G63TDSM
Mar 26, 2006
Brownsville, Texas
I just wanted to know if an exhaust manifold leak will affect the boost on the turbo. :confused:
Now exactly how big of a leak would cause that? You would thing it would need to be a big one... I recently blew the ol t25 an did a bt28 an am having problems car cuts out when i get into any boost. When I had everything off I ported out my 02/exh man, well i dropped my exhaust man when I got to work to port it so I ran over to the solovent tank an washed er off an found a tiny crack nothing to big but went all the way through....
Did a boost leak at the turbo intake an only got 5 pounds on the gauge, hear no leaks for only 5 pounds exept in the valve cover which has a slight crack which I knew abou(changing cover this weekend)
