exact place to hook up MBC is?
Generation1JeY
547
Aug 5, 2004
San Diego, California
ok i read the vfaq on installing mbc, and i also read the techi articles on exactly how to do it, but what i need is pictures, or atleast someone to explain where to plug in on my particular car.
I got a turboxs standard MBC and right now i have it hooked up to the stock nipple on the turbo outlet elbow, and then to the waste gate actuator, is this right?
in the tech article it said u should always have something plugged into the intake mani for exactly boost pressures for acurrate boost controlling.
If i'm doing something wrong tell me so i can fix it asap to get this mbc working properly.
oh and by the way i cant exactly tell if its working or not right now because my waste gate actuator is broken, so just tell me the correct setup so when i replace my wstegateactuator it will all be up and running.
you need to eliminate some vac lines first...you really only need 2 lines, and the rest can be capped off. The nipples that need to be capped come from the air box, the turbo outlet elbow, and the t from the wastegate actuator.
leave one of the t section open, and plug the boost controller into that. the other source will come from the blow off valve line. T it off, run a vac line from there and plug it into the bottom of the controller.
sorry if im making it sound complicated, cause i suck at words
ok so, straight from the wstgate actuator plug that into the mbc, then tee of the line from the bov to the intake and plug that in?
is that right?
