evoscan/ceddy mods questions
foxracing4500
336
9
Jan 21, 2012
Europe
alright I am catching on quick with flashing the ecu but logging seems to be a pita. Everyone says evoscan so I got it, selected openport 2.0 and Mitsubishi MUTIII (the DSM/3000gt etc crashes). Try using Live Map Tracer and my load % is all F***ed up but I remember seeing another member with the correct values and everything, what could I be doing wrong?
screenshot, it might be simple but its 4am where I live so I im deadbeat tired.
also I know the option CAN 2006+ is selected but I still get the same thing.
try a different version of evoscan. i use 2.8
I can log mine and i can flash...but i still have little to no idea of wtf i am doing =(
Recheck your baud rate..seems off. Mines 15625.
i'll try that, also I am on evoscan 2.9. Right now just getting a feel for it. I logged my tps and I am just tossing numbers out but I think with my foot off the pedal it read 10.xxx% and floored it read 99.6xx. sound right?
EDIT I know why my baud rate was messed up, I had the wrong option selected in the left hand corner but same situation still applies.
I started with 2.9 and it didn't seem to work with everything right. I tried 2.7 & 2.8, and 2.8 seems to work right.....BUT, I have yet to get the LiveMap to work. I have given up on it for now and I just use the standard logs graphed out after a run or I use an SD card in the Tactrix box and look at it later. I would love to know how to make livemap work, but so far I've done pretty well just tuning off short logs after a pull. I wouldn't be able to mess with it without wrecking the car if it were realtime anyway.
The throttle issue is normal. The formula for it is off. There's a fix for it on EvolutionM. Just look up "Evoscan throttle 12%".
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
