evo III engine, talon ecu.
jaden
85
Dec 21, 2008
st.marys, ON, Canada
ok so... heres my problem. I bought a talon that had the engine swapped for an evo III engine and it has a talon ecu in it with dsm link. i can't find dead times or global % settings for these injectors on a talon ecu. i believe the evo III had 510cc's in it.
1 - (450/New injectors) * 100 = global adjustment at base fuel pressure
In your case, 1 - (450/510) * 100 = 11.7% (12%)
As for deadtime, I'm not too sure how to calculate it but based on RC550 that are 180 I'd say 150 would be a safe start point but I would want to confirm that first.
yea i thought that i could just estimate it by the rc550's and just go a little lower to but i saw that the evo 9 injectors accually have a slower opening time than stock 450's. is there an accuall calculation for this?
the last two deadtimes appear to be same as 1g 450cc according to the values in the link i posted. I know dsmlink just uses one deadtime value instead of each voltage. I don't see a consistent number to use.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
