Evo III Engine- Question
socalrcr
58
Nov 25, 2006
El Cajon, California
I was given a Evo III- engine with some goodies on it for my 95 GsX but the bad part is it needs rebuilt, (cousin says it's knocking and using oil) after a previous rebuild.
I am guessing that i need to go .20 over bore so new pistons are in store, so i was just gonna get a pair of forged pistons (hopefully inexpensive if there are any) i'll just reuse the internals and have someone install new rod and main bearings. and then i was gonna have ArP head studs installed and maybe freshen up the head. This is what i wanna do is there anything i am missing. And is the Evo III motor a 6 bolt ?
This is what is installed on the engine:
agp turbo , turbonetics wastegate and bov, ffwd cams, aeromotive fpr , 780cc injectors,
sbr clutch , maft translator and 3.5'' gm maf
This is what is inastalled to manage the stuff on the engine:
greddy emanage , innovative wideband, 190lph pump, keydriver stage3 chip
What i have to install also is :
SAFC II (blue face) and Greddy Profec B spec- II
I am hope that after the rebuild with this stuff installed i'll have close to 400 whp. I am fairly new to DSM stuff but is this set up a good set up or do i need to relook things.
And when i order pistons for this Evo -III motor do i just order them as if this was a regular 1995 GsX motor is does it need to specially ordered for this specific engine with the added .20 over bore.
Is 7 bolt as strong as the 6 bolt or is it weaker.
And thanks for the reply...........
7-bolt: Better head, better pistons
6-bolt: Better rods, less of a chance of crankwalk
So in order to keep the crank from possible walking and make the bottom end as good if not better than a 1g i need to put a leash on the Evo III rods and just upgrade them to 1g's or just use aftermarket ones right or ?
thanks again
You can't eliminate CW....however, there are many precautions to take that would "slow" it down. I've only seen one 7-bolt walk in my life. It's not as common as everyone thinks. Yes, 1G rods are stronger than 2G rods. I believe EVO III rods should be good for 90% of us on this board.
Ya i'll probally just order a set of oversized wiesco forged pistons and oversized rod and main bearings and put it together after its machined of course. And i think it should be fine.
I have the Evo-III tranny also so imma see if i can get ahold of a Evo-III diff so i can use the Evo-III tranny. And then i think i'll be on my way to my 400 whp.....:thumb:
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
