evo 9 turbo
95whitegst
537
Aug 14, 2009
lancaster, Pennsylvania
this might be a dumb question but can i got the evo 8 or 9 turbo on my gst my buddie has an 8 and a 9mr turbo in his bedroom and he said i could just have one if i wanted just wanted to know if i could fit it and if so what parts needed to be put on to make it work (jpipe oil feed and return lines ect..)
The EVOs have a different bolt pattern on the o2 housing and center section. It would be best to post pics of the turbo, correctly identify and then weigh out the options.
While running an OEM from another car is sometimes a cheap upgrade, it can also end up costing more time and money than its worth.
yea i knew the o2 bolt pattern was a little different. There pretty big turbos and since its just falling into my lap for free if i can use it without to much trouble i think it would be a good upgrade
here is what the 9 turbo looks like
http://www.gruppe-s.com/Evo/evoeng/evo9turbo.jpg
here is what the 8 turbo looks like
http://www.turbochargers.com/store/images/evo8mit.JPG
i also know they face the opposite direction in evos idk if that would pose a problem or not with install
also im sure i would need to set it up the opposite direction move the powersteering setup and maybe the alternator...also invest in a maft so i wouldnt have to worry about recirculating my bov from the other side all in all sounds like it could take some work anyone think its worth it? it would be something original though which would be cool
