Evo 6.5 rs TME
zross1
138
Jul 7, 2004
Pocatello, Idaho
Can anyone tell me if this is a Evo 6.5 rs tme? Do any other 16G's come with a twin scroll turbine housing besides the 6.5 rs tme? The only thing that makes me think it isn't is because the TH says 9.8 and also the compressor housing reads:
49378-01520
TD05HR-16G-9,8T
030717020
The 6.5 rs tme only comes in a 10 cm turbine housing right? Do any of the titanium turbine wheels/shafts come in the smaller 9.8 turbine housing?
According to the model chart breakdown I've got at home the Evo VI Tommi Makkinen edition came with either a TD05RA-15GK2-10.5T for the GSR models, or the TD05HRA-16G6-10.5T for the RS models.
THe TD05HR-16G6-9.8T is the stock turbo from an Evolution VII, not the TME. It may also be the turbo on the Evo VIII's, but my chart doesn't go that high.
mind posting that chart? seems like something that might be useful in the future
Evo I-II
TD05H-16G-7 - Inconnel Turbine, Aluminum Compressor
Evo III
TD05H-16G6-7 - Inconnel Turbine, Aluminum Compressor
Evo IV
TD05H-16G6-9T - Inconnel Turbine, Aluminum Compressor
Evo V
TD05HR-16G6-10.5T - Inconnel Turbine, Aluminum Compressor
Evo VI
TD05HR-16G6-10.5T - GSR - Inconnel Turbine, Aluminum Compressor
TD05HRA-16G6-10.5T - RS - Titanium Alloy Turbine, Aluminum Compressor
Evo VI TME
TD05RA-15GK2-10.5T - GSR - Titanium Alloy Turbine, Aluminum Compressor
Evo VII
TD05HR-16G6-9.8T - GSR - Inconnel Turbine, Aluminum Compressor
TD05HRA-16G6-9.8T - RS - Titanium Alloy Turbine, Aluminum Compressor
Thanks, so could I put on a normal undivided turbine housing and make it work on a dsm?
So what evo 16G has a turbine housing that will bolt up to a dsm manifold?
The evo 3.
If you want to use an Evo 4 or later turbo, you can either bolt on the evo manifold and relocate/remove PS and the alternator, although I dont know if the front engine mount would be in the way of the downpipe. Or build a custom manifold. Evo turbos are everything theyre cracked up to be, but its extremely labor intensive to get it to work when you can just bolt on the evo 3 16g (same comp wheel as the later evos, just reversed)
Technically the Evo 1-3 will bolt up, but the 3 is the best design of those that will.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
