Evo 3 o2 housing question
'97boostinGST
1,102
Mar 1, 2010
Oxnard, California
Will the stock t25 OR 14b line up with the Evo 3 housing?
I also have installed a PR downpipe, has anybody had any problems with this setup?
Either would work, but the o2 housing upgrade alone is overkill for either turbo.
Note- the Evo III o2 housing will not fit many DSM downpipes because of the bolt spread difference.
Obviously you'll need to take into account the difference in angles with these two O2 housings, but the Evo will bolt on to either turbo. It's funny to see how friggin' huge the wastegate opening is on the OEM 2G compared to an unported Evo. But of couse the opposite is true for the turbine exit holes.
http://www.dsmtuners.com/forums/bolt-tech/262519-i-cant-find-downpipe-angled-evo-o2-housing.html
http://www.roadraceengineering.com/parts/evo/evoO2-differentangle2.jpg
http://www.roadraceengineering.com/parts/evo/evoO2-differentangle.jpg
http://www.plymouthlaser.com/evo.htm
http://www.dsmtuners.com/forums/bolt-tech/274606-mr-o2-housing-vs-evo-iii-o2-housing.html
EDIT: Justin beat me to it. :)
Ok the turbo part is good, anybody out there know of a downpipe that lines up with the evo housing?
