Even 105C Caps Leak TCU / ECU
booosting92tsi
90
Nov 1, 2004
Philadelphia, Pennsylvania
Even 105C Caps Leak TCU / ECU :barf:
My A/T went into LIMP MODE, I checked my TCU, and guess what, leaky capacitors. These capacitors were rated at -55c to +105c, celsius not fahein.........
Check out the pic below for the mess I found in my TCU, this could happen to you to either on your ECU or TCU.
After I replace these leaky capacitors, do you all think my LIMP MODE might go away?? will a tiny little leaky capacitor cause the tranny and/or TCU to go into LIMP MODE?
It's not a generic capacitor temp rating it's a failure of the seals on these caps that causes the leakage and the damage from the leakage. These are the same caps as the ones on the ECU and they just fail over time. Oce you clean up the leakage, repair the board and replace the caps, you have a good chance of it working again.
Steve
is there any way to replace those caps with non electrolytic capacitors?
:thumbdown No way! Stay with electrolytic Capacitors! Same Voltage, Same Capacitance, Same Temp. Range.
Don't go to :barf: radio trash(shack) :barf: , 9 outta 10 times you won't find the exact same one you need. I didn't............. :mad:
Go to Digikey..........
settle down no barfing necessary
theres a freakin digikey catalog sitting less than 10ft from me
:D
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
