ETS intercooler licp with MAP o2 dump fitment? *Updated with new pics*
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
I have a MAP o2 housing (external dump) on my car now for my evo3 16g and I just ordered an ETS street kit (through group buy :thumb:) Looking at the clearance now and it seems either the licp won't fit at all or it'll be a really tight fit.
Looking for input from anyone using this same set up and preparing myself for any modification if need be.
Thanks
You may have to take it off and cut the dump a little shorter, after that you can run some flexible exhaust hose from it to route it around the lower intercooler pipe after that.
Yea, that may be my solution. Dreading removing the o2 as its always a hassle getting the back bolts. Anyone else run this set up?
Thank
You know looking at it in the picture it looks like you could leave it on and just cut it right after where it meets with the downpipe, I'm not sure how much space you have there though between the dump tube and dp for the cut. Anyway looking forward to see some replies.
I am hoping if I have to cut it I can leave it on as well!
Thanks
Update with new pics! Maybe with newer angles someone could see if the licp will fit?
Thanks
Honestly i never saw the pictures until now. The licp should work you may have to wrap the dump though or nudge the piping gently to clear the dump
