error code 24
aliczander
281
Aug 9, 2004
millville, New Jersey
Hay guys i just replaced my tb, and put a cai on, and now i have a little bit of a problem... im gettin error code 24 which means 1 or 2 of 3 things
1) my throttle position sensor voltage is low
2) " " is high
3)throttle position sensor voltage does not agree with map
I have no idea what to do to fix this, also i broke off the bolt that hold the ground wire on the throttle plate ajuster could this be causeing the problem?? :cry:
never mind guys, it went away by its self, i guess the ecu just had to learn the new map :thumb:
