Enough Flow?????
LA97GST
287
May 24, 2004
Slidell, Louisiana
I own a 1997 Eclipse GST with a 2.5 inch downpipe, 2.5 inch hi-flo cat, and a 3 inch cat-back. I want to install a internal gated 20g, but do I have enough exhaust flow? I will only be running 20 psi. I also have 2100 clutch and light flywheel with intake system.
You will most likely have to start porting the items mentioned above by my fellow canuck
I will port the o2 to 2.5 inch and buy an evo III maniflod. The turbo will come fully ported with a 34mm wastegate valve. I hope this will work. Also will 750cc injectors and a SAFC II with a 255 pump handle the fuel?
98spydert said:
along with an adj fuel pressure regulator to keep that stupid 255 under control, they will
Alright...thanks man. I just need to order all this stuff. Does anybody know any good dyno tuners in the New Orleans area?
