engine wiring
can anyone please tell me where this parts goes? i just did a 6bolt swap into my 97 eclipse.
It's the MDP sensor. I believe you connect the hose to a manifold pressure source like teeing into the line that runs to the fuel pressure solenoid.
Hopefully a 2g owner who's done a 6 bold swap can confirm.
steve was referring to the picture in the bottom right that has a vacuum line coming from it. You can do that or others have sourced from the brake booster line. I'm not sure if one is more correct than the other. Just make sure it has a source from the intake manifold as steve said.
You should be able to figure out the others from the link posted above.
