engine swap
zachv17
Jul 11, 2004
little york, New York
Ok I have done some searching and looking around and can not find the answers to my questions so here it is. I have a 2.3 stroker I want to drop into my 93tsi awd sometime this week. I am wondering if I will have to switch anthing to drop it in? I know if it was a 95 or later there would be alot to switch but because it is still a 1g I am not sure.. I was wondering if the same clutch would work pressure plate and what not, and what if anything else I would need to switch, thanks in advance everyone
Clutch and flywheel should be ok. As long as it is a 6-bolt stroker motor, it should drop pretty much right in for you.
If you have a 6 bolt block, everything should be drop in and go.
If youre talking stock clutch, youll probably burn it up soon enough. Any supporting mods/tuning?
I have an act 2600 clutch, as for supporting mods i have a big front mount, afpr,walboro 255, logger. I am probably going to order some 850cc injectors and have not really decided what I want to tune with, any suggestions? It has a T3/T4 Turbo- 57 Trim Stage 3 .50AR COLD / .63AR HOT -T3/T4 Tubular Manifold.Comp Cams 101200 Series Lift .411”/.395”,[email protected] 262/261 106deg . bored .20 over. basic info to help with suggestions. I will probably go with Link unless you have some thing easier and cheaper! LOL
Yes that should drop in just fine.
Go with DSMlink or dsmap with those size injectors for your tuning.
