engine swap wiring issues
guitarplayer
Mar 5, 2005
Philadelphia, Pennsylvania
i have a quick question, if i swap to the 2.0 non turbo in a 93 talon dl, will i have to take the dash apart to rewire the car for 2.0, or is there an easier way? The engine is going to be a 92 6-bolt. And yes I allready have a 97 gsx, so I don't need to heard the whole "buy the turbo car speech". This car is my daily drag, since my gsx has been put out of condition (broke timing belt and bent valves). :cry:
Their is one plug you will have to rewire It stems off right by the ecu and goes up toward the dash harness. It is very easy to wire I just spliced the 2.0 plug to the 1.8 dash harness. (might have been the other way around but it doesn't matter) Everything works in my dash ecept the gauges won't dim only on full light (oh no). Make sure to grab the 2.0 gauge cluster because I had trouble with the tach working. I just swapped them out and it worked perfect.
Any questions with the swap just let me know.
My car will soon be running again, after I get married and have a little more cash....Damn timing belts ruin everything!
