engine stalls
stangtalontsi
Mar 3, 2004
dover, New Jersey
i got a question i will be driving normal all of a sudden the car will just stall on me and i would have to start it up again it only happens when i get off the gas and put the clutch in i had this problem before and i adjusted the idler switch and that worked but now this happens it only happens like 1 time a day while driving for like 3 hours in a day any ideas what i can do my idle on the car is set at 1,300 so let me know if any 1 knows what i can try or do i just have to adjust the blow off
Hey stang: once again you posted in the wrong forum. You will probably get mroe results and feedback if you place your questions in the right forums man.
everything he said, plus its prolly the infamous IAC.
read up www.vfaq.com and post in correct forums to get best results:thumb:
