Spyder Engine Stalls after warmed up.
silencer25321
Sep 5, 2010
Parlin, New Jersey
I have been having a problem with my 2G Eclipse Spyder. After the car warms up it stalls out and fails to start.
Recent replacements:
-fuel filter
-spark plugs
-fuel injector cleaner
I believe the problem is either dirty injectors or fpr. FYI i also have a Walbro 255 L/H installed with stock fpr. Everything ran fine until I took a road trip from NJ to FL and back. Problem started by giving me problems when accelerating from 2-3k RPM. (once in that range it would start choking, out of that range no problem) any help would be appreciated thank you ahead of time. :hmm:
I have check the fuel lines and they are all ok.
CAS? sorry don't know what that one stands for.
Coolant sensor, I dont get any error codes and temp is always ok no overheating or anything.
thnx for the reply guys.
any other ideas?
It happened to me once when a hose (that gois in the firewall where warm water flows for heating the interior) failed, was unattached or leaking. It stalled out on low idle and was very hard to start until it cooled down.
Fastened the hose in my case and problem went away.
Hope its something small like this.
Sincerely Alex
