Engine Specs for a 98 Eclipse GS-T 4G63T Engine?
CrimsonGod
Dec 1, 2004
Columbus, Georgia
Does anyone have the specs (bore x stroke, rod length, compression, piston displacement, etc etc) for a 1998 Mitsubishi Eclipse 4G63T Turbo Engine???? This would be greatly appreciated.
Thanks,
James
You must be a newbie.... welcome aboard either way.....
Learn to use these 2 links.....
<a href = http://www.vfaq.com/FAQlocator-index.html> VFAQ</a>
<a href = http://members.shaw.ca/costall/1000Q/> 1000 Questions</a>
Also, there is a rather easy to use SEARCH feature in the upper right hand corner....
Here are the answer to your questions - the rod length, but I bet if you search for it you will find it....
