Engine Rebuild (Winter Project)
Zepyr
Oct 21, 2009
Butte, Montana
Well what I want to do is rebuild my engine with the strongest parts that I can get. I am not really constricted by price but I do want to rebuild my motor myself and not have some shop do it.
What I want to know is what exactly I need to replace (engine wise),
1. Run 400hp
2. >20 PSI
Thank you,
Zep
A well maintained 6bolt with some arp's will handle 400hp and more than 20psi all day.
Run a search, you will get your info you need much faster than waiting for replies.
The strongest possible and not restricted by price is pretty ridiculous for your goals.
A eagle/wiseco combo with some 272's and a good street turbo is what I would do. I won't even begin to type the exact parts out, or it will take all day.
yea, the cheapest way is just crank the boost up on a good head gasket, with arp studs. the long block can hold 400, with a strong turbo, and enough fuel, and flow
well start with a bottom end best way to find on is look up 4G63 rotating assembly so u dont have any guess work and the price can range from very cheap tp 1300 for good stuff. magnus motorsports make top of the line best of the best internals if ## rich enough u can buy a crate engine!!
