Engine problems. Help please. (kinda long)
eagle_talon90
264
3
May 2, 2004
Regina, SK, Canada
So here's the problem, I can't get the car to stay running on its own, it turns over and starts but it will die immediately, but If i give it some gas it will rev up pretty high and die again. If i keep giving it some gas i can get it to stay running but there's major idle surge and its idling really high. I had a friend start the car and give it some gas to keep it running and i unplugged the ISC and the TPS, and this didn't change anything, it stayed running but with major surge and high idle. I've tried messing around with the cam angle sensor to no avail. I've tried doing a boost leak test, but no matter what i do i can't get my boost gauge to read any pressure no matter how much air i pump in (tried with bicycle pump and small compressor). It is a rebuilt 2.3L stroker motor. Any one have any ideas as to what else i can check for/what could be wrong? Sorry for the long post but I've bin trying to get it running for 2 weeks now and no success. Any help is greatly appreciated.
When you said you messed with the cas, does that mean you have checked the base timing? I know it won't run, but pull the plug on the coil pack and the engine fuse, have a friend crank the motor over while you check the timing with the timing light.
hmm, i haven't checked base timing yet. I thought that if the timing marks on the crankshaft Sprocket, oil pump sprocket, and cam gears all lined up then the timing would be okay, wouldn't it? All i did with the CAS was loosen the two nuts on it and try rotating it clockwise/ counterclockwise to see what that would do, I also turned it 180* but that didnt do anything either
Alrite so just a little update here, this problem is fixed and the car is running fine now. Turns out the problem was a MASSIVE boost leak, caused by me kind of forgetting to put the lower injector insulators on during the rebuild, thus causing no compression whatsoever, LOL:p. Oh well, haha, we all make mistakes sometime.
Glad to hear you resolved your problem. Even better was the fact that it was one of those, oopps mistakes and easily fixed. Happy boosting.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
