Engine mounts, upgrade or not?
Race94
1,151
Jan 6, 2003
Puerto Rico
Well i am doing a 6-bolt swap should i put in upgraded engine mounts?
Do i need to buy the mounts for a 6-bolt even if it's going on 2g?
i think they are all the same except the drivers side, which you would want to use a 2g mount on the 6 bolt engine
are you sure they are all the same? I just sold my 1g prothane motor mount inserts and ordered 2g motor mount inserts. If they are they same they why is the front and rear just inserts, when on a 1g only the front roll stopper uses an insert? Also why wouldnt they just sell it as 1 kit then?
  • Wanted 6 bolt NT water pipe
    • chrisman287
