Engine Mount In Way Of 56 Trim Pte Turbo
TT_NS
203
Dec 2, 2003
Any one els have a problem putting the oil return line on the 56 Trim PTE turbo? I Also noticed that the anti-freez line that goes behind the turbo to the oil filter housing dosent fit with the new turbo on so i guess im going to have to custom bend one. What did you guys do?
You just gotta spin it around. It'll all fit good.
You can run a rubber line to the oil filter housing or just bend one like you said. Im in the process of installing my PTE 60 trim and my return line fits fine(also a rubber line). are you guys plugging that water line bolt just under the water pipe that interferes with the compressor housing?
WOW. Damn I gotta say that turbo looks WAY outta place, LOL!
Nice tho, very nice :) :thumb:
yea there was a bolt that i got with the oil line kit that fit right in there. so i pluged it up not sure if it will leak yet but it seems to be no big deal
The motor mount, either get a 45* return line flange at the turbo to push the line away from the mount, or just grind the lip down off it.
