engine cooling questionable?
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
ok so lately, when i start my car up, the first 5-10 min of it running the temp. gauge almost hits the red and will stay there for about 3-7 secs then slowly return to normal. temp, but then sometimes it will do it again, but ill turn the heater on and feels like normal, no cold air blowing.....?
ideas? theromstat? water pump? blocked radiator?
well, im kinda broke ATM LOL.... i should have money in a week or so, it can't hurt it like that?
If you can afford gas, you can afford a thermostat. If the thermostat sticks closed, you will probably warp the head.
Check the water level first, make sure it's full of coolant.
thermostat is like 15 dollars. if it is sticking and you dont replace it you could run into more problems soon.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
