Engagment, Disengagement, and shifting problems!!!
ALLBoostAWD
186
3
Oct 13, 2004
Prattville, Alabama
I installed an ACT 2600 and XACT flywheel. The STEP height was correct when I installed it. I drove the car for the first 500 miles lightly breaking in the clutch, no problems. I noticed that my slave cylinder was leaking and a started having problems getting the car into gear (TB OEM). I replaced the slave sylinder with a new OEM one from SB and tried the extended slave rod in it, still didnt fix the problem so i put the OEM rod back in, bleed the clutch, and installed a SS clutch line. Now if I drive the car it does not want to go into gear and is very notchy, it grinds and I have lost some pedal pressure even after bleeding it forever. I am almost to the point where i am just going to start replacing things; pivot ball, fork, master cylinder:notgood:. Any suggestions?? Thanks
Ill try re-bleeding the system and adjusting the clutch out some. Ill let you all know what happens, I dont think the assembly is bad, me and a freind checked it out right before the installation of the clutch. Thanks for the help.
