emissions questions?
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
before i start off yes i have searched for these topics and found some good info but i havent really found a clear answer. i removed my charcoal canister and put a filter on the big rubber line and ran it under the car. now the other line that is attached to the hard line on the firewall do i just cap it? and the i do not need the purge control solenoid anymore corect, since i removed the whole charcoal canister system? the solenoid has two lines that run under the intake manifold and connect to a row of hard lines. just remove the rubber lines and cap them correct?
the solenoids on the rack against the fire wall. can i remove the purge control solenoid valve? i have just finished removing my charcoal canister and was wondering about this. i have a 1993 eagel talon 2.0 turbo FWD. thanks
im sorry but the cars just chillin and its nice out and i want to drive it. i have the gas tank breather line, the big rubber hose coming out of the firewall, vented and put a small filter on it so nuthing gets sucked back in. the 1g ecu dosent read emissions really since its OBD1 i have never heard of anyone havin troube with a CEL. i apprecaite your help.
now as far as the small line on the firewall can i just cap it? its a hard line that switches to a rubber line then back to a hard line and runs along the firewall.
