Emissions delete. What's this solenoid?
v8s_are_slow
2,824
280
Sep 30, 2002
Panama City, Florida
Okay, doing a lot of work on my car right now and doing the emissions delete crap while I'm at it. On the side of the intake manifold (driver's side), there's a solenoid and the vacuum hoses that go behind the coil pack. I've already taken it off, but just wanna check to see what this is. Thanks.
From drivers to passengr side it goes fuel pressure solenoid, EGR solenoid, EVAP control solenoid.
It's on the manifold itself on the very end of it on the driver's side of it. The vacuum lines run behind the coil pack. I'll try and post a picture when I can.
The part is already off. Just showing where it went. Any ideas?
You can disconnect it all if you need. I think you have to keep the solenoid plugged in on a 2g or you will get a code. I may be wrong.
Okay, I figured I could get rid of it but just wanted to be sure. And have Ecmlink so not worried about codes. Thanks though.
