Electrical Problem*** Please Help
AnDYy187
108
Nov 4, 2004
Sterling Heights, Michigan
When I was hookin up my turbo timer, I have came across a problem. Nothing will turn on, nor will it turn over. I was wondering if anyone knows what could cause the problem. I am guessing a wire came loose or somthing. But I have no clue what wire it could be because there is so many of them.
Did you hardwire your turbo timer? The best way to figure out a problem like this is to pull the turbo timer along with all associated wires out, and put it back to stock, see if it starts (hopefully it will) and then go through your install again, just being a little more careful this time around.
Jason :dsm:
