H@xtGSX
- 1,093
- 11
- Aug 9, 2011
Carlsbad,
New Mexico
Agreed. The line supplied with every boost gauge I've bought has been totally inadequate. Use regular vacuum hose and clamp it to the gauge fitting.
Rather then drilling holes in the firewall you can just stab the steering boot and run your wires and hoses thorough there. I personally have my wideband harness, boost source, and oil pressure source running through there and have had no problems. Its rubber so it hugs it and keeps it sealed and you don't have to keep drilling or enlarging holes in the firewall.well that makes sense guys Thanks I'm gonna need a long piece of hose and i made a hole in the fire wall on the driver side gonna have to make it bigger!
I have replaced the compressor cover o-ring before (common boost leak spot) and I just replaced the hotside (my old 6cm housing was cracked all to crap, I'll be posting pics in my build journal soon) while swapping to a 7cm housing and an external wastegate setup.Nathan, have you ever had to rebuild your 14b? I did a blt last night and heard a bubble in my oil pan... It's not smoking or leaking and boosts like normal, but I think the seal is worn out. I just don't know how difficult rebuilding one is. The exhaust housing has a little crack forming also, so I figured I'd stick a new one on since it looks like I'll have to take it apart anyhow.
. Just hit me up.If you need any vacuum line or fittings let me know I have plenty and also the boost leak tester with air compressor. Oh yeah and an open garage. Just hit me up.
Sup guys sorry i diddnt know wether or not to start a new thread, but im looking to buy a dsm and i need some one that knows about these cars to help me out. Im 17 years old and this is going to be my first car im looking to buy a 1995 eagle talon esi thats on craigslist. Its listed at 2500 dollars and he has already agreed on 2 grand. I would buy the turbo model but my dad does not want me driving a turbo car. I need someone to help me out to tell me if this is a good buy for me. This car will be my daily driver. http://elpaso.en.craigslist.org/cto/2762004026.html
i took off my smic to clean it i put it back and made sure everything was tight no way boost could escape but there is no doubt i can feel i lost power i took all the piping off and put it back together this time tighter and still i dont get the same 'pull' when the turbo spools.
any help would be great let me know how much for the sm. What you said makes sense when i drive i cant feel the turbo kicking in at all its sadso my smic is a gonerany help would be great let me know how much for the sm. What you said makes sense when i drive i cant feel the turbo kicking in at all its sad
I forgot to mention I put premium gas at some gas station in the middle of nowhere and now my engine sounds like a dam diesel engine at idle :O
oh that's nice of him to put 87! what an a##! I'm going to go buy some octane booster to get rid of the knock for now. I really need a dsm expert to look at my car
