1G Egt install diagram?
Jcboeh
Nov 28, 2017
Michigan Center, Michigan
I have a 1g, it has an evo 3 manifold with I’m guessing is a sensor for an egt, sadly it’s not hooked up. I was looking to get a gauge and hook it up or take it out, any advice or links? I uploaded a pic for you guys. thanks in advance and sorry for the noob question.
http://www.dsmtuners.com/threads/installing-air-fuel-ratio-gauge.361066/
http://www.dsmtuners.com/threads/how-to-install-a-aem-wideband.243242/
Don’t waste your money on a air fuel gauge, they are nothing but a blinking light show.
If your going to get a gauge then I would suggest a proper wide band gauge and controller. The link above can help you, witch kit you get is up to you, AEM, innovate, WB the list goes on.
If your going to remove it, make sure to plug the opening so you don’t have a major manifold leak, I do believe the fitting size is 18mm x 1.5
Hope this helps you some.
