2G EGR block-off plate
boostedgsx95
127
Jun 19, 2009
Topeka, Kansas
I've been considering gettin this EGR block-off plate. Can someone please tell me where the hell my EGR valve is and what I can re-move after that install? Is it gonna make any difference at all? (I think the EGR is under intake manny but not 100%)
It's right under the throttle body, you don't have to remove it, just put a block-off plate between the valve and the openings on the manny. I removed mine just for the simple fact of the old one bit the bucket. You can remove vacuum lines on the intake manifold. Use the taboo speed shop diagram.
Remove the battery, the battery tray and the brackets. You should see it clearly, it looks like a smaller blow off valve. After installing the block off plate, you should feel slightly faster throttle response, but this mod decreases mpg a LITTLE BIT. Not enough to actually care :thumb:
The EGR valve helps your car more efficiently and completely burn fuel by recirculating a portion of your exhaust and running it through the combustion process again. This results in a cooler, more complete burn of the fuel which decreases you car's noxious emissions by prohibiting the formation of some harmful gases.
It's kinda pointless to block it off. It shuts off itself off at WOT anyways. Its mainly for cruising speeds on the freeway.
