EGR block off plate bolts stuck
spic21
240
May 14, 2010
albany, Louisiana
im trying to get my egr block off plate off to drill a hole for a vacuum line for my 4 bar gm map sensor. the plate is mount on with some allen screws, and these suckers are tight. i almost broke my t handle allen wench trying to remove them. anyone have any ideas on how to get these things out?
Get a set of allen sockets at sears or any other parts store. Then you can use a ratchet and get more torque on it. :)
Why are you set on going there for your vacuum source? I just have mine teed into the line off my fpr.
sorry whats a fpr. but because i was told it had to be a dedicated.
quote from snowborder714
The vacuum line should be directly from the intake manifold, and as short as possible. Nothing else should be tee'd off of it either.
tried this
Sounds like he's setting it up to datalog exhaust backpressure - at least I hope that's what he's trying to accomplish.
here forum where he told me that. and someone on ecm link told me that is what they did as well. it about half way down. its for SD
http://www.dsmtuners.com/forums/newbie-forum/383554-hate-asking.html
Behind the EGR plate are 2 holes, though. One goes to the head/exhaust and the other port goes to the intake manifold plenum. That's the one he needs to tap. It works well for me as a dedicated vacuum/boost source that's needed for good idle control in speed density. I'm the one that suggested it to him. :)
^^^ Good call.
spic21 - Try using a torch to heat up the bolts.
will do allen sockets and torch. guess im going back to tool store
here another question. i have all my interior you cleaning and running wires. anything i should do before replacing it all
Oh, one other thing I forgot to mention on the Link forums. Try to match your hose barb fitting's inner and outer diameter with the MAP sensor you're putting on. That way you just have a hose going from the barb fitting to the sensor with no reducers in line.
Also, a little more background. On my car, I noticed a big improvement in idle with a dedicated port like this vs a throttle body port. I suspect the throttle body ports were just too small to get good vacuum resolution. Obviously this only applies to a speed density setup.
Hope this helps.
Hope this helps.
what size barb did u use? is there any chance u have a pic?
I honestly can't remember. I just happened to have the right size laying around. If you take your sensor with you to the store, that should give you an idea of what you need. Then get the right size drill and tap to attach it to the block off plate.
I do have some pics I can send you when I get home. PM me your info if you would like them.
cool will do. im still waiting on the sensor. so guess that postponed till next week. ok though gives me time to go buy so new tools:D
If all comes to nothing, try vice grips. They got me out of a lot of trouble.
yea me to. only problem is theres no way it grab them. the head are dome type. ebay crap. if and when i get them out im going to replace them with nicer bolts
