ECUflash Ecuflash help!!!
The only reason im asking is because i downloaded the newest rom/def combo. And when i scale my injectors to the 560's that are in my car, it runs so lean it damn near wont idle. I have to scale the evo injectors to 478 with a latency of -.048 just so it will idle and my fuel trims wil be ok.
Now, my main issue is under wot, my car will pull until ~4500 then pop and lean, rich, pop and lean. If i keep the throttle at or below 60%, it will rev out clear until redline. This has really got me stumped
i would have evoscan if it would process my order. I login, and choose add to cart, then checkout, and nothing... no emails, or anything..
It should take take you to a paypal login screen. You sure you're doing it right? I believe there is a option to just pay with credit card also.
Are you using the Evo 8 ecu? If so pm me. I have a .hex with the correct scalings for the 2g maf in a evo 8 ecu.
