ECU Turboing question
98gsspy
272
Feb 27, 2006
Raleigh, North Carolina
Looking to turbo the sypder and was pricing things out. Now the questions: Can you tune the stock ECU, can you just re flash the ECU, what do you need to tune the stock ECU, or if all else fails what ECU upgrade do you recommend? Thanks a bunch.
First you need to check if you have a eprom, most likely you dont since its a 98 and a n/t. You can pick one up in a junk yard real cheap or get one online from $150-$300. Then your best bet would be to invest in dsmlink, since you can change the setting whenever you want, with a flashed chip you wont beable to chang anything. Go to www.dsmlink.com and they will give you all the info you need. Its the best tuning device for the money about $600, only thing better would be AEM EMS, but cost around $1500.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
