ECU trouble?
Turbo Demon
50
Aug 23, 2005
Alvin, Texas
Has anyone out there had this problem or ever heard of anything like it?
Every time I turn off my engine for more than a few minutes, the ECU resets. Normally the battery has to be disconnected for a pretty good amount of time for that to happen. It seems to sometimes reset in under fifteen minutes. Other times it will take hours. I have an Optima red top in it that is fairly new and have cleaned and retightened both terminals twice. Any ideas? :confused:
My suggestion would be to check the grounds around the ECU, and make sure all of the connectors are firmly seated.
Checked connections, everything is good. I can't figure it out. I've been reading the shop manual too. I can't find anything there either. OMG
Might I suggest replacing your red top with the battery that worked just fine before? ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
