ecu swaps
ok so ive got the new ecu, however i cant seem to figure out exactly what green and green/wehite wires need to be swapped.
Also does anyone know if this is a dsm ecu?
md153253
Also how can I tell if the wires have already been swapped I mean after the swap the green wire should be where?
### vfaq doesnt specify whether or not the wire is green after or before the swap
No that is not a DSM ECU. Some searching returns that it is a 1990 Mirage or Galant 2.0L SOHC, automatic ECU and has since been superseded by MD161181: ECU Part Numbers for DSMs
Pin 6 is originally green with white stripe; pin 14 is originally green. That means after the swap, pin 6 will be green and pin 14 will be green w/ white: 1G ECU Pinouts
Interesting, that Galant ECU was in my car the whole time, im surprised it started honestly if that were the case.
Thanks so much, roblem solved
As an afterthought, it may have been possible that the cover was switched with one from a DSM; that is to say that using the part number only is not a great indicator in determining what ECU you had. Here's what it should look like (non-EPROM). The big giveaway for a turbo ECU is the white rectangular board with black dot on the right side; this is the knock board. It makes sense to assume that, since non-turbo 1Gs did not have knock boards, that other cars around that era that were not turbo will also not have this:
EDIT: Some non-turbo ECUs, not T/E/L ECUs mind you, actually do have knockboards. See this to correctly identify your ECU -- http://www.dsmtuners.com/forums/newbie-forum/471597-1g-dsm-knock-sensor-code-31-non-turbo-car.html#post153347456.
Or an EPROM as in the pics in this thread:
http://www.dsmtuners.com/forums/articles-tuning-ecu/381713-1g-ecu-eprom-vs-non-eprom-visual-comparison.html
You do have a valid point.
Ill have to double check that ecu.
After the swap, the car runs good, but im getting a code 14 now, and my stock boost gauge doesnt work anymore.
Any ideas?
I dont know i double checked the wires over and over, spliced a green with a green/white and vice versa.
I hope i didnt get the wires wrong. anyone else ever have this issue?
Injector 4 is the closest one to the throttle body correct? ### thats what I double checked the pin out with in relation to the position of where injector 4 was on the ecu pin out.
Here are the symptoms
-Stock boost gauge no longer works
- cel code 14, tps
- idling around 1000
All i did was swap the ecu, and retape some wires under the hood.)
And im the type of person that hates seeing that cel light on.
Its a 90 eagle talon tsi awd manual, and I just swapped in a 92 gsx manual ecu
