Compatible swaps?
Status
Not open for further replies.
eclipse1986
Jul 18, 2005
Philia, Pennsylvania
Would an Eclipse/Talon Turbo 4G63T 90-94 - Engine, 5-Speed AWD Transmission swap into a N/A 420a frame if that frame was a 90-94 as well. Now I understand with enough fabrication virtually any motor can be swapped, but I’m looking for a clean simplistic swap. I would appreciate any input you can give me.
you seem to be a little confused. 420a engine was only put in eclipse/talon from 95-99.
1990-1994 n/a =4g63 non turbo WHILE 1990-1994 turbo= 4g63-turbo
1995-1999 n/a =420a non turbo WHILE 1995-1999 turbo= 4g63-turbo
- OR -
1995-1999 convertible= 4g64 n/t WHILE 1995-1999 turbo convertible= 4g63-turbo
So basically 1990 through 1994 there was no "420a" frame. However if you were to get a 1990-1994 n/a or 1995-1999 convertible n/a the swap becomes MUCH more realistic.
Ok, let me rephrase my question because I did not get the direct answer I wanted, thank you for your input however. If I have a 90-94 Talon with the 4g63 N/A motor in it and I wanted to swap that out for a 4g63t will it be a direct swap? If not what, problems may I run into or what extra parts will be required?
tech Guide > Tech Articles > Fuel and Turbo > How to install a turbo 4g63 into your 4g63nt By mavisky.
Please read the thread as opposed to pm'ing me repeatedly until I give you all the answers you need.
Sorry, I was just posting a reply stating that I should have done a thorough search from the beginning, because I found all the information I needed in the 1g n/t section. I’m a rookie member for a reason, sorry again.
Status
