ecu swap??
yes. 90's turbo ecu's are interchangeable with only 90 turbo cars. 91-94 turbo ecu's are interchangeable with only 91-94 turbo cars, 95-96 turbo ditto, 97-99 turbo ditto..
I thought you could run a 91-94 in a 90 or vice versa by switching the pins on the harness.
yes you can run a 90 in a 91-94, and vice versa. Just have to switch 2 pins in the ecu plug.
The 90 car will run with the later ECU and the 2 pins swapped but you will have problems with the tach bouncing around. There are various fixes including the newest adaptor Keydiver is selling.
Steve
Ok so what all needs to be done to get a 90 ecu to work in a 91. Just swapping the two pins?
Everything i read is about putting a 91-94 ecu in a 90.
