Ecu Mix Up
SlipGear
65
Nov 30, 2004
Laurel, Delaware
Well today I just bought a '90 Eclipse GSX. The ecu that was in it was fried. So i took my friends '91 Ecu. Well It started fine and ran not so good. Well after searching the forums tonight i found out that the ecu where different. By using the '91 ecu did i mess anything up?
LIKE black91awdturbo SAD YOU DIDNT MESS ANYTHING UP, YOU SAD I WAS A 90 GSX, I'M SURE ITS A 5 SPEED,THE ECU YOU NEED WILL HAS A CODE ON TOP, THAT SHOULD BE MD128625 ,IF IT IS A CAFL EMISSIONS CAR, THEN THE CODE WILL BE DIFFRENT. BUT IF NOT THEN THIS IS THE CODE, ECU YOU NEED.YOU MIGHT WANT TO SAVE THE FIRED ECU BECAUSE SOME PLACES GIVE MONEY FOR CORE ECU'S:cool:
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
