1G ECU Damage
kingcobb
May 17, 2006
Winnipeg,
My idle is really wonky of late in my 92 :talon: TSi AWD, it goes up and down 500rpm between 1000 and 1500 when I'm moving and it's in neutral, as soon as i stop, the idling stops too. I've checked everywhere for leaks in the intake, nothing and my wastegate hose is on, so what could the problem be? My ECU?
If i ordered a new ECU that's chipped, and re-programmed (that's what I wanted to do in the first place.) will that solve the problem? I think it's the ECU. It thinks there's a vacuum leak somewhere when there really isn't. pls help! Thanks
If someone wants to talk on msn, my addy's [email protected], that'd be wicked, I've got a lot of other questions too. thanks
Sounds like you have idle surge. I'd suggest reading these two vfaq's and going through there suggestions.
http://www.dsm.org/how-tos/tttt/tttt3.html
http://www.vfaq.com/mods/wayback/BradBauer/engine/surge.html
You may also want to test your whole intake for leaks, by pressurizing it. To build a boost leak tester check out,
http://www.vfaq.com/mods/ICtester.html
If you wanted to check ECU, you can pull out your ECU for a visual inspection. Take the cover off and find the 3 cylinders (capacitors) on the board. Look to see if they have any goo leaking under them, burnt board, etc. Then look all over the board for other components that might've fried.\
EDIT: Ah, I guess I'm too slow now.
And you might want to better clarify your problem. From re-reading your description it says your IDLE jumps around while your MOVING. Like Minkel asked^^ Do your rpms fluctuate while your "moving" holding the accelerate steady at a rate of speed, or only when your "idling" at a stop, neutral/park, etc.
I think he means when he is coasting to a stop with the car in neutral or with the clutch depressed. Once you come to a dead stop, the idle goes back to normal. Mine does the same thing and has for the past 5 years. I dont even pay attention to it any more
LOL, thats the problem, it's just when i'm coasting in neutral or when the clutch is pressed and i'm just rolling up to a light or sumthing...like the car can be rolling the slightest little bit, and it'll start to idle funny, but when the car is completly stopped, it stops. So i've read a lil on those links u guys' gave me...what should i proceed to check first...or do first?
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
