Gigaah
- 400
- 1
- Aug 7, 2004
Janesville,
Wisconsin
I looked around I wasn't able to spot a post that specified the components for the ECU. I cracked open my ECU and found one of those long thin black components (ISC driver I think it was called) cracked open. See picture.
I cracked open my ECU to see if it was EPROM and found that. So I guess I'll just socket the ECU at the same time as I repair that damaged component. I just need to know exactly what that component is so I can order one.
If anyone knows specificly off hand what component it is and exactly what socket to order I'd be grateful.
I can order from digikey,mouser, mcmaster car, and grainger so if I know what component and socket to order its not a big deal.
My car runs and idles ok. Maybe a little low and rough upon decel but the motor is stroked and no sure of what cams it has. I just got it and am just now going over the car to see what was done to it over the last 18 years of its life.
Any info is great otherwise I'll pull the ecu back out and spend a couple hours figuring out what to get and where to get it. I did search but didn't find anyone specifying which components to get. Thank you in advance for anyone saving me some time on this one. I work and obscene number of hours and still and trying to get this car all figured out and straightened out.
