General ECU Bin files for EPROM 90 awd
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
I have all the stuff I need to burn chips using tunerpro. BUT now I cannot find the files I need so they can be edited. the car is a 90 talon AWD.
where can they be found all the places I found before are shut down or dead
Beat to the punch :)
Most people use the E931 image to modify. It's from the 91-92 Federal Turbo ECU but will work in the 90.
Both it and the Tunerpro XDF file are in the files section of the DSM-ECU Yahoo group. http://autos.groups.yahoo.com/group/dsm-ecu/files/
thanks for the help unfortunately I don't know whats up, a long time ago I had tuner pro V3 and these files downloadedand it all worked great.. I since lost that computer and downloaded the newer tuner pro. when I open these bin and ecu files everything is all 000's with no information loaded into them. before it had the baseline info in it. any heads up on this or can someone send me the older version of tunerpro
The new version of Tunerpro:
Once you open the bin and import the .ecu file hit ctrl - f2 and change the bin size (hex) to 8000. Then from the xdf menu save as and give it a name. In the future just use that xdf you created.
(As posted by Miles Frederick at:) http://www.labattz.com/phpBB2/viewtopic.php?t=11843&highlight=tunerpro
This should get you on the right track with the new software and should get rid of those zeros.
